Resultados 1 al 10 de 85
Tema: [astra F] Trasplante techo solar original. Nuevo proyecto.
pity* [astra F] Trasplante techo... 12-06-08, 13:39
Kenny Re: [astra F] Inplante de... 12-06-08, 13:44
kadett1.8beauty ostras, en 2008 a Pity se le... 19-09-19, 14:30
UZIELGAL Re: [astra F] Inplante de... 12-06-08, 13:49
Joshman_GSI Re: [astra F] Inplante de... 12-06-08, 15:31
SCHWX Re: [astra F] Inplante de... 12-06-08, 16:14
RiegerGSI16v Re: [astra F] Inplante de... 12-06-08, 17:09
BiLLyTK Re: [astra F] Inplante de... 12-06-08, 17:17
Flama Re: [astra F] Inplante de... 12-06-08, 17:54
Escarpa Re: [astra F] Inplante de... 12-06-08, 17:58
3DFx Re: [astra F] Inplante de... 12-06-08, 18:04
pity* Re: [astra F] Inplante de... 12-06-08, 18:34
BiLLyTK Re: [astra F] Inplante de... 12-06-08, 18:44
kike_gsi8v Re: [astra F] Inplante de... 12-06-08, 23:07
pity* Re: [astra F] Inplante de... 12-06-08, 23:12
deividelingles Re: [astra F] Inplante de... 12-06-08, 23:21
turigsi Re: [astra F] Inplante de... 12-06-08, 23:21
pity* Re: [astra F] Inplante de... 12-06-08, 23:30
kike_gsi8v Re: [astra F] Inplante de... 12-06-08, 23:35
juanda_53 Re: [astra F] Inplante de... 12-06-08, 23:39
juanda_53 Re: [astra F] Inplante de... 12-06-08, 23:40
pity* Re: [astra F] Inplante de... 12-06-08, 23:46
kike_gsi8v Re: [astra F] Inplante de... 12-06-08, 23:51
Cresko_gsi Re: [astra F] Inplante de... 13-06-08, 00:30
kadette16sv Re: [astra F] Inplante de... 13-06-08, 07:42
Flama Re: [astra F] Trasplante... 13-06-08, 09:15
UZIELGAL Re: [astra F] Trasplante... 13-06-08, 09:34
p1cs1 Re: [astra F] Trasplante... 13-06-08, 10:07
sayonarab Re: [astra F] Trasplante... 13-06-08, 11:10
Luke GSI Re: [astra F] Trasplante... 13-06-08, 11:25
Kami Re: [astra F] Trasplante... 13-06-08, 13:06
dunkan Re: [astra F] Trasplante... 13-06-08, 13:10
pity* Re: [astra F] Trasplante... 13-06-08, 13:40
dunkan Re: [astra F] Trasplante... 13-06-08, 21:30
xujuanmi Re: [astra F] Trasplante... 13-06-08, 21:34
AdriAstra8v Re: [astra F] Trasplante... 13-06-08, 22:25
pity* Re: [astra F] Trasplante... 13-06-08, 23:03
madness Re: [astra F] Trasplante... 13-06-08, 23:54
pity* Re: [astra F] Trasplante... 20-06-08, 10:07
BiLLyTK Re: [astra F] Trasplante... 20-06-08, 11:34
CorsaGSI"A" Re: [astra F] Trasplante... 20-06-08, 11:48
Flama Re: [astra F] Trasplante... 20-06-08, 11:52
sayonarab Re: [astra F] Trasplante... 20-06-08, 11:53
pity* Re: [astra F] Trasplante... 20-06-08, 15:18
pity* Re: [astra F] Trasplante... 20-06-08, 15:29
juanda_53 Re: [astra F] Trasplante... 20-06-08, 16:26
pity* Re: [astra F] Trasplante... 20-06-08, 17:50
juanda_53 Re: [astra F] Trasplante... 23-06-08, 00:27
dieguin Re: [astra F] Trasplante... 20-06-08, 17:12
cicli Re: [astra F] Trasplante... 20-06-08, 18:15
Claw Re: [astra F] Trasplante... 20-06-08, 19:46
sayonarab Re: [astra F] Trasplante... 20-06-08, 20:47
pity* Re: [astra F] Trasplante... 20-06-08, 21:36
dunkan Re: [astra F] Trasplante... 20-06-08, 21:43
pity* Re: [astra F] Trasplante... 23-06-08, 15:34
RandyGsi Re: [astra F] Trasplante... 23-07-08, 13:34
kike_gsi8v Los delanteros en origen... 10-05-15, 17:15
gassofa Hola compañero, lo primero... 10-05-15, 18:19
kike_gsi8v Ya te he dicho lo que he... 10-05-15, 18:22
UZIELGAL En algún sitio tengo el brico... 16-09-19, 00:41
Jaimagoras The walking post... vaya... 26-01-15, 15:14
gassofa Me preguntaba si tienes el... 15-09-19, 14:29
ikatz Rojo positivo directo de... 15-09-19, 15:03
UZIELGAL Buenas Según el word del... 19-09-19, 17:05
K_V6 Yo el único q no conecte era... 20-09-19, 10:45
kadett1.8beauty en que coche lo montaste... 20-09-19, 11:15
juanda_53 Re: [astra F] Trasplante... 23-07-08, 01:37
LUISITO Re: [astra F] Trasplante... 27-07-08, 15:20
deividelingles Re: [astra F] Trasplante... 27-07-08, 20:14
nando33 Re: [astra F] Trasplante... 31-07-08, 22:47
K_V6 Re: [astra F] Trasplante... 31-07-08, 23:07
pity* Re: [astra F] Trasplante... 04-08-08, 00:39
K_V6 Re: [astra F] Trasplante... 04-08-08, 22:11
juan04 wenas estoy en la mismo tema... 24-01-15, 12:11
kike_gsi8v Si te fijas en la parte... 10-05-15, 23:06
gassofa Buenas, me vuelto loco y he... 10-05-15, 00:01
gassofa A que te refieres con el... 10-05-15, 21:44
remintonestil Mira haber si te vale.... 15-09-19, 15:22
k-dett Es la foto de mi brico. En mi... 15-09-19, 18:37
remintonestil Exacto! La tenia guardada de... 15-09-19, 18:54
k-dett Me alegro de que te guste y... 16-09-19, 23:16
    19 Oct, 04
    C'mon Sport Edition
    Predeterminado Re: [astra F] Trasplante techo solar original. Nuevo proyecto.
    Pity de mayor quiero ser como tu!!! con eso te lo digo todo jajajajaja.
    Un abrazo sossio.
    Garaje B Motorsport Power!!!
    08 Dec, 05
    calibra
    Pity, respecto ala grasa a usar, hay grasas de marca Wurth que son de composición de tefon y demás, son las ideales puesto que el agua no las arrastra y siempre por años y años hacen su efecto, al contrario que las grasas litio que son semi-solubles en agua.
    Como te dije antes, cuestan caras de +++++++. Solucion? Vaselina de farmacia, va que te cagas, es mas duradera que la litio y cuesta dos duros . Yo esoty arto de comprarla, anda que en la farmacia pensarán........ NO te cabe naaa!!!:^_^:
    Con el sindrome de diópeles!
    27 Feb, 07
    astra c20let
    Si las guías llevan plástico, lo mejor es que le eches grasa blanca. Como la que se usa por ejemplo en la palanca de cambios.
    Es una grasa neutra frente a plásticos y gomas.
    Saludetes.
    de esa tengo en casa la original de opel. La guias del techo son de aluminio, y los cables que lleva para moverse son de acero. Sigo hechandole la misma? habia pensado en la grasa esa color aceite de toda la vida....
    Cita Iniciado por Claw Ver mensaje
    Un abrazo sossio.
    sossio, sabes que no! jaja
    Cita Iniciado por sayonarab Ver mensaje
    XDXDXD, que cabrito!! Anda que cuando yo estaba liao con las motos y estaba todo el dia pidiendo en la farmacia aceite de ricino (sirve para cagar XD) XDXD
    Bueno lo de grasa para los railes, en principio a esta zona NO le llegaria el agua, a no ser que le hechases agua con el techo abierto. La zona de los railes, queda justo por dentro del cristal del techo, y si entra agua, no le llega, va directo a la bandeja recogedora de agua. Entonces no se yo que grasa utilizar.....
    Gracias y un saludo!
