Resultados 1 al 10 de 20
Tema: Astra C18XE no arranca
    22 Mar, 17
    Te dejo la lista de códigos de fallo del c18xe:
    Código:
    Siemens Simtec 56.0/56.1
    Fault:
    12 	Initiation of diagnosis. 	n/a
    13 	Oxygen sensor 	Open circuit
    14 	Coolant temperature sensor 	Voltage low
    15 	Coolant temperature sensor 	Voltage high
    16 	Knock sensor signal circuit 	No change in voltage
    19 	Incorrect Revs per Minute (RPM) signal (crankshaft sensor) 	Incorrect signal, check sensor
    21 	Throttle position sensor (TPS) 	Voltage high
    22 	Throttle position sensor (TPS) 	Voltage low
    23 	Knock control module signal 	Out of range
    24 	Vehicle speed signal (VSS) 	No signal
    25 	Injector valve 1 	Voltage high
    26 	Injector valve 2 	Voltage high
    27 	Injector valve 3 	Voltage high
    28 	Injector valve 4 	Voltage high
    37 	Check light (fault code lamp) 	Voltage low
    38 	Oxygen sensor circuit 	Voltage high
    39 	Oxygen sensor circuit 	Voltage low
    44 	Oxygen sensor 	Lean exhaust (weak mixture)
    45 	Oxygen sensor 	Rich exhaust (rich mixture)
    48 	Battery 	Voltage low
    49 	Battery 	Voltage high
    52 	Check light (fault code lamp) 	Voltage high
    53 	Fuel pump relay 	Voltage low
    54 	Fuel pump relay 	Voltage high
    55 	Engine Control Unit (ECU) faulty 	Check chassis earth and ECU connector.
    56 	Idle air control 	Voltage high
    57 	Idle air control 	Voltage low
    61 	Fuel tank vent valve 	Voltage low
    62 	Fuel tank vent valve 	Voltage high
    69 	Intake air temperature sensor 	Voltage low
    71 	Intake air temperature sensor 	Voltage high
    73 	Mass air flow temperature 	Voltage low
    74 	Mass air flow temperature 	Voltage high
    75 	Torque control (automatic) 	Voltage low
    76 	Torque control (automatic) 	Continuous signal, ignition retard long
    81 	Injector valve 1 	Voltage low. Injector short circuit to ground.
    82 	Injector valve 2 	Voltage low. Injector short circuit to ground.
    83 	Injector valve 3 	Voltage low. Injector short circuit to ground.
    84 	Injector valve 4 	Voltage low. Injector short circuit to ground.
    87 	Air Conditioning (A/C) cut-off relay 	Voltage low
    88 	Air Conditioning (A/C) cut-off relay 	Voltage high
    91 	Oxygen sensor heater 	Voltage high
    92 	Camshaft sensor 	Incorrect signal
    98 	Oxygen sensor heater 	Voltage low, open circuit
    La cosa sería ver si después de cambiar el sensor del árbol de levas seguía marcando el fallo. Mira también si tiene algún otro fallo guardado.
    05 Feb, 17
    Salamanca
    Prueba a limpiar bien el alojamiento del sensor, con una pequeña miga de grasa que no lo deje entrar completo el coche no arrancara, saludos.
  1. Restauración Astra GSI (C18XE)
    Por rubenpaz en el foro Vuestros Coches
    Respuestas: 46
    Último mensaje: 20-04-20, 17:09
  2. Me presento con un astra c18xe!
    Por Borjika en el foro Bienvenidas y Presentaciones
    Respuestas: 10
    Último mensaje: 17-06-16, 23:40
  3. Astra GSI C18XE
    Por METROPLEX en el foro Compra/Venta/Cambio
    Respuestas: 7
    Último mensaje: 14-11-14, 23:32
  4. Astra gsi c18xe
    Por el_jakoo en el foro Vuestros Coches
    Respuestas: 13
    Último mensaje: 20-05-14, 11:48
  5. Mi Astra GSI16v c18xe.
    Por Mamoru en el foro AsTRa
    Respuestas: 9
    Último mensaje: 09-12-05, 15:14
