Resultados 1 al 10 de 203
Tema: Investigación sobre cuadros digitales de Omega A/Senator B/Vectra A 2000 16V
    22 Mar, 17
    Aunque cambies el chip de parámetros, en el manual en Alemán pag. 64 te dice que el dentado del generador de impulsos de un 6 cilindros y un 4 cilindros no es el mismo, y otra cosa que imagino que también la sabes, cada rotación del sensor de RPM en un 6 cilindros equivale a 3 pulsos y en un 4 cilindros equivale a 2, ése cuadro no marcará jamás bien en un 4 cilindros, siempre errará en velocidad y RPM, así que cualquier cuadro vale para cualquiera no es cierto.
    Cito del manual en alemán del cuadro antiguo:
    The various LCD instruments differ in their design
    the tachometer and in the selector lever position (see section
    7.1 "LCD instruments").
    All vehicle-specific data is in the removable program memory
    (Figure C 7518) included. The error codes are also stored in the program memory
    and the tank calibration value is saved.
    The program memory is a very reliable component. He
    should only be replaced if
    • an incorrect program memory is installed, or
    • Error code 51 is saved.
    Only the program memory assigned to the vehicle in the LCD instrument may be used
    be installed (see section 5.2 "Test program,
    Check program memory code and display "). If the program memory is defective
    only this must be replaced. The LCD instrument is not replaced in this case.
    The program memory is offered separately in the part program (see
    "Program memory" tables, section 7.2, and "Program memory
    Codes ", Section 7.3). The program memory code must be in addition to
    Catalog no. will specify.
    After replacing the program memory, the fuel gauge must be new
    be adjusted (see section 8 "Adjusting the fuel gauge").
    In the case of a defective LCD instrument, only the LCD instrument is
    to replace. The program memory becomes the defective LCD instrument
    removed and inserted into the new one (Fig. C 7519)
    "In the case of a defective LCD instrument, only the LCD instrument is
    removed and inserted into the new one"
    En caso de avería, simplemente tienes que cambiar el chip de parámetros.
    05 Feb, 17
    Salamanca
    De avería, ahí no dice nada que el de un 6c funcione en un 4c, y marque bien, en caso de avería remplace el chip de parámetros, poner uno de un 6c en uno de 4c nunca funcionará bien, no tienen ni el mismo dentado en la caja ni los pulsos son iguales, pero bueno, has investigado mucho y se agradece todo lo que estas haciendo, pero no me hagas comulgar con piedras de molino, en el manual que puse en Portugués también lo dice y gente que lo ha comprobado y lo ha montado, cuantos has montado tú, y con ésto doy por zanjado el debate que tú empezaste al decir "no es cierto" pero.... si es cierto, un saludo.
    22 Mar, 17
    Entendido, a partir de ahora dejaré que seas tú quién responda a las cuestiones técnicas, en caso de que desees responderlas por supuesto.
  1. [OTROS] Cuadros digitales para calibra
    Por p1ns en el foro Electricidad
    Respuestas: 43
    Último mensaje: 22-04-19, 15:55
  2. Cuadros digitales
    Por UZIELGAL en el foro Personales & Off Topic
    Respuestas: 10
    Último mensaje: 09-03-13, 23:44
  3. Interiores OMEGA 3000 24V en VECTRA 2000
    Por KiLm3R en el foro Personalización
    Respuestas: 11
    Último mensaje: 28-04-08, 01:43
  4. Omega 3000 177cv o vectra 2000 150
    Por xt600e en el foro General
    Respuestas: 22
    Último mensaje: 01-05-06, 17:29
  5. Cuántos modelos de cuadros digitales hay?
    Por MrZoGs en el foro Personalización
    Respuestas: 6
    Último mensaje: 15-01-06, 17:00
