Resultados 1 al 10 de 19
Tema: Opel Kadett E 3.0 24v jiji
    27 Feb, 07
    astra c20let
    Predeterminado Re: Opel Kadett E 3.0 24v jiji
    a q no tienes huevos de montar eso alli dentro
    no me lo calientes que le veo con un motor de desguace y su coche en la puerta de mi casa XDXDXD
    Si Marc tu dame ideas xDDD.
    Bueno ahi va
    Car
    1988 Vauxhall Astra Originally a GTE 8v, Polar White
    Engine
    2962cc 30XE V6 24valve conversion,3.0ltr Courtenay Hi-torque cams,
    Courtenay re-programmed ECU, 2.5" dia Jetex S.S. Exhaust system
    4 bar fuel pressure regulator, Courtenay Enlarged throttle body
    Traction control flap removed, Green cone filter
    Gearbox
    Standard F20 5 Speed Manual, Courtenay Billet XE flywheel
    Uprated Courtney H/D Clutch, ATB LSD, (Planned equal length shafts)
    Brakes
    Front - Redrilled GM 288mm V6 Vented discs and Calipers
    Rear - GM 200mm drums.
    Suspension / Steering
    Front - Independent Mac pherson strut,
    Up rated V6 springs and Blisten dampers with anti-roll bar & strut brace.
    Rear - Semi-independent trailing link,
    Up rated springs and Blisten dampers with anti-roll bar.
    Polyurethane Bushes through out.
    PAS system installed from 16v due to weight over front wheels.
    Wheels & Tyres
    6.5 x 16” Irmscher Softstars with 195x45x16 Falcons
    Exterior
    Standard (body work coming soon)
    Interior
    Standard beige/rainbow Recaro trim with Early Door Cards, Black Dash, Snap-off steering wheel with OMP steering wheel.
    I.C.E
    Kenwood 9070R Mask CD head unit, JBL GTO 4” replacement dash speakers, JVC 6x9's on back shelf
    Performance
    235.5bhp @ 5722rpm, 224.2lb/ft @ 4566rpm
    Standing 1/4 13.907 @ 100.66mph
Nombre: kadett 3000.jpg
Visitas: 230
Tamaño: 113.0 KB
Nombre: kadett 3001.jpg
Visitas: 186
Tamaño: 100.0 KB
Nombre: kadett 3002.jpg
Visitas: 540
Tamaño: 124.7 KB
Nombre: kadett 3003.jpg
Visitas: 215
Tamaño: 120.8 KB
Nombre: kadett 3004.jpg
Visitas: 221
Tamaño: 123.5 KB
Nombre: kadett 3005.jpg
Visitas: 205
Tamaño: 105.6 KB
Nombre: kadett 3006.jpg
Visitas: 213
Tamaño: 97.5 KB
Nombre: kadett 3007.jpg
Visitas: 205
Tamaño: 106.7 KB
    11 Oct, 05
    kadett Berlina
    Este chaval cualquier dia va a pillar un calenton que habra que rectificar hasta la tapa de balancines XDDD
    27 Feb, 07
    astra c20let
    :XD::XD::XD::XD::XD:
    Si claro que facil como los dos habeis tenido/ tenis un turbo bajo el capo, jijij. Mi calenton algun dia a lo mejor se apaga bien cuando tenga pasta para mantenerlo, o bien cuando encuentre una buena oportunidad.
