buenas compañeros, nose si ya habra salido por aqui pero mirar que pasada de corsa de bulgaria
.. bueno sobretodo el motor, 326cv atmosferico...
os dejo los datos:
Results from initial testing: 11.22@1/4mile
Drag Racing Record for Class A in Bulgaria
Fastest naturally aspirated Corsa in the World.
Most powerfull NA 2L. C20XE in the World.
Engine
As a base we decided to use the well known in the motorsport world C20XE engine.
ECU: Haltech PS2000 + Racepack Dash IQ3Buy from shopConnecting
Rods: Extreme Tuners Custom Connecting RodsBuy from shop
Pistons: 87 mm, 13:1 Extreme Tuners Custom PistonsBuy from shopConnecing
rod bearings: UPG Specification
Main Bearings: UPG Specification
Cylinder Head: CNC Heads
UKHead gasket: Athena MLS 1.9mmBuy from shop
Camshafts: Extreme Tuners Custom
Valves: 1 mm oversize
Valve springs: Custom double springs
Retainers: Custom Titanium
Lifters: Custom Mechanical
Camshaft pulleys: Cat Cams
Throttle bodies: 48 mm Jenvey WTCC
Exhaust manifold: 4-2-1 BTBBuy from shop
Bolts: ARPBuy from shop
Clutch: Custom 4.25” Twin Plate
Fuel system: Nuke PerformanceBuy from shop
Fuel Injectors: Bosch 440cc
Oil system: Titan Motorsport Dry Sump
Gearbox: Custom
Differential: Quaife ATB Helical LSDBuy from shop
Handbrake: D2Buy from shop
Brake System: UPG
os dejo algunos videos y la pagina de la preparacion completa de este monstruito
http://upg.bg/en/projects/upg-carbon-corsa
un saludooo!
					 corsa c20xe de carbono 326cv atmosferico!!!!
			 Iniciado por reinoso
