Página 8 de 17 PrimerPrimer ... 678910 ... ÚltimoÚltimo
Resultados 71 al 80 de 193
Tema: [PEDIDO CONJUNTO] Esferas de Plasma
    06 Jun, 06
    kadett gsi
    Predeterminado Re: [PEDIDO CONJUNTO] Esferas de Plasma
    Cita Iniciado por Leaniz16V Ver mensaje
    CICLI> -1 Set of "special" dials (I will send you a pic of the design of the dials. Are similar to the factory dials) with EL-Foils cutted and a chip controlled inverter. For Astra F GSi16v - 110 EUR
    K_V6> -1 Set of cutted EL-Foils with chip controlled inverter and wires for Vectra A ( EL1000 ? - WHITE ) - 48 EUR
    YO> -1 Set of cutted EL-Foils with chip controlled inverter and wires for Astra F ( EL1000 ? - WHITE ) - 48 EUR
    Bufarron> -1 Set of EL-Foils for DIY with chip controlled inverter and 8 contact pins ( el001 ? - WHITE ) - 38 EUR
    Eduskap> -1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For Vectra A - 7Krpm, 220kmh, 60l (VECTRAAP - Blue/white) - 95 EUR
    B.A.D> -1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For Vectra A - ¿?rpm,¿?Kmh, ¿?L (VECTRAAP - ¿?) - 95EUR
    Bixo> -1 Set of Dials, EL-Foils cutted, wires and chip controlled > inverter. For Astra F GSi16V - 8Krpm, 240kmh, 50l (ASTRAFP - Blue/white) - 95 EUR
    Astur_gato> -1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For Astra F GSi16V - 8Krpm, 240kmh, 50l (ASTRAFP - > Blue/white) - 95 EUR
    Vectra2> -1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For CalibraTURBO- Falta especificar el modelo concreto (hay dos) uno con los numeros en horizontal y otro con los numeros sobre el arco de la esfera. Tambien falta decir, la capacidad de L de gasolina y el maximo que marca el reloj de temperatura del motor, 100 o 110 ¿?¿? 95€
    Vectra2> -1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For VDO´s (VDOOPCP) - > Blue/white
    Leaniz16v> -1 Set of cutted EL-Foils with chip controlled inverter and wires for Vectra A ( EL1000 ? - WHITE ) - 48 EUR
    Gracias Billy!!!!
    P.D. Tu dirás el número de cuenta y cuándo ingresar!
    confirmado
    gracias chicos...
    Astur_gato, los precios que me ha dado de las esferas son las estandar, que son sin logo...
    15 Feb, 07
    Vectra
    Billy perdona, ya te dije por privado que esta semana estoy de mañana y me es imposible, aunque lo estoy intentando llamando al banco para que me la hagan ellos, pero está complicado, si no, el lunes a la mañana sin falta te hago el ingreso, cuenta con ello. Ya lo siento, de verdad.
    06 Nov, 07
    Astra gsi16v
    venga ke ya hay ganas... jeje
    From Asturias con amor.
    Astra gsi 2.0 16v del 93
    No había oído yo nada de las agujas.
    Eso que dice de micro-led serán unos simples SMD como los que se usan para la iluminación del teclado de los móviles. Te lo pillas en una tienda de electrónica por la décima parte de dinero que te cobrarán, todo es cuestión de ver cómo colocarlos.
    pago de EDUSKAP recibido, empiezo las gestiones...
    ahora pondré la lista definitiva del pedido ok?
    ESTOY EN EDICION
    Vectra2> -1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For CalibraTURBO - 8Krpm, 20-280kmh, 60L - 110ºC (CALIBRAP - > Blue/white) 95€
    -------------1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For VDO´s (VDOOPCP) - > Blue/white 31,5€
    ----------------1 Set of EL-Foils for DIY with chip controlled inverter and 8 contact pins ( el001 ? - WHITE ) - 38 EUR
    Vectra2, lo de los "needle kit´s" aun no es seguro, en caso de que no estuvieran aun disponibles, te devolvería el dinero correspondiente, ya te diré algo...
    bueno, siento ser tan repetitivo, pero quiero dejar claro todo e informaros de cada paso...
    ya le he mandado el correo con el pedido, se lo he puesto asi:
    *1 Set of cutted EL-Foils with chip controlled inverter and wires for Vectra A ( EL1000 ? - WHITE ) - 48 EUR (K_V6)
    *1 Set of cutted EL-Foils with chip controlled inverter and wires for Astra F ( EL1000 ? - WHITE ) - 48 EUR (Leaniz)
    *1 Set of cutted EL-Foils with chip controlled inverter and wires for Vectra A ( EL1000 ? - WHITE ) - 48 EUR (servidor)
    *1 Set of EL-Foils for DIY with chip controlled inverter and 8 contact pins ( el001 ? - WHITE ) - 38 EUR (Bufarron)
    *1 Set of EL-Foils for DIY with chip controlled inverter and 8 contact pins ( el001 ? - WHITE ) - 38 EUR (Leaniz)
    *1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For Vectra A - 7Krpm, 20-220kmh, 60l (VECTRAAP - Blue/white) - 95 EUR (eduskap)
    *1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For Astra F GSi16V - 8Krpm, 240kmh, 50l (ASTRAFP - > Blue/white) - 95 EUR (astur_gato)
    *1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For CalibraTURBO - 8Krpm, 20-280kmh, 60L - 110ºC (CALIBRAP - > Blue/white) 95€ (vectra2)
    *1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For VDO´s (VDOOPCP) - > Blue/white - 31,5€ (vectra2)
    *1 Set of 'special' dials with EL-Foils cutted and a chip controlled inverter. For Astra F GSi16v - 110 EUR (cicli)
    Estamos todos no?
    15 Feb, 07
    Vectra
    Gracias por la confirmacion billy. Por mi parte está todo correcto y claro. A ver si luego la instalacion está tan clara, jeje.
    a ver, me ha dicho que ha actualizado la informacion de los needle kit´s
    aqui podeis ver fotos e instrucciones de montaje, aunque todavía no están a la venta por lo que me dice, que tardarán en tener stock y demas
    aqui:
    http://www.xtuners.com/enshopneedle.htm
