como es posible que un c20xe de 190cv sea más barato que el de 181???
ahora que como ese...
Complete engine 2,0 16V STW engine
starting from 286PS with 8500 U/min, torque 244Nm with 6780 U/min, around 180° turned cylinder head (EL channels now in driving direction forward), special steel cam shafts with own profiles over changed belt price increase propelled, mechanical tappets Ø 32mm, larger valves (also with shank Ø 6mm available!), Forging piston, longer steel piston rods with h-shank, dry sump oil system with 2 suction stages, 2-Scheiben sinter clutch with steel flywheel, butterfly valves injection system EFI with flap Ø 50mm, etc..........
PRICE: starting from 32.699,00 EUR
dios que bestialidad... :twisted:
