Resultados 1 al 10 de 193
Tema: [PEDIDO CONJUNTO] Esferas de Plasma
    Predeterminado Re: [PEDIDO CONJUNTO] Esferas de Plasma
    No había oído yo nada de las agujas.
    Eso que dice de micro-led serán unos simples SMD como los que se usan para la iluminación del teclado de los móviles. Te lo pillas en una tienda de electrónica por la décima parte de dinero que te cobrarán, todo es cuestión de ver cómo colocarlos.
    pago de EDUSKAP recibido, empiezo las gestiones...
    ahora pondré la lista definitiva del pedido ok?
    ESTOY EN EDICION
    CICLI> -1 Set of "special" dials (I will send you a pic of the design of the dials. Are similar to the factory dials) with EL-Foils cutted and a chip controlled inverter. For Astra F GSi16v - 110 EUR
    K_V6> -1 Set of cutted EL-Foils with chip controlled inverter and wires for Vectra A ( EL1000 ? - WHITE ) - 48 EUR
    YO> -1 Set of cutted EL-Foils with chip controlled inverter and wires for Astra F ( EL1000 ? - WHITE ) - 48 EUR
    Bufarron> -1 Set of EL-Foils for DIY with chip controlled inverter and 8 contact pins ( el001 ? - WHITE ) - 38 EUR
    Eduskap> -1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For Vectra A - 7Krpm, 220kmh, 60l (VECTRAAP - Blue/white) - 95 EUR
    Astur_gato> -1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For Astra F GSi16V - 8Krpm, 240kmh, 50l (ASTRAFP - > Blue/white) - 95 EUR
    Vectra2> -1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For CalibraTURBO - 8Krpm, 20-280kmh, 60L - 110ºC (CALIBRAP - > Blue/white) 95€
    -------------1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For VDO´s (VDOOPCP) - > Blue/white 31,5€
    Leaniz16v> -1 Set of cutted EL-Foils with chip controlled inverter and wires for Vectra A ( EL1000 ? - WHITE ) - 48 EUR
    ----------------1 Set of EL-Foils for DIY with chip controlled inverter and 8 contact pins ( el001 ? - WHITE ) - 38 EUR
    Vectra2, lo de los "needle kit´s" aun no es seguro, en caso de que no estuvieran aun disponibles, te devolvería el dinero correspondiente, ya te diré algo...
    bueno, siento ser tan repetitivo, pero quiero dejar claro todo e informaros de cada paso...
    ya le he mandado el correo con el pedido, se lo he puesto asi:
    *1 Set of cutted EL-Foils with chip controlled inverter and wires for Vectra A ( EL1000 ? - WHITE ) - 48 EUR (K_V6)
    *1 Set of cutted EL-Foils with chip controlled inverter and wires for Astra F ( EL1000 ? - WHITE ) - 48 EUR (Leaniz)
    *1 Set of cutted EL-Foils with chip controlled inverter and wires for Vectra A ( EL1000 ? - WHITE ) - 48 EUR (servidor)
    *1 Set of EL-Foils for DIY with chip controlled inverter and 8 contact pins ( el001 ? - WHITE ) - 38 EUR (Bufarron)
    *1 Set of EL-Foils for DIY with chip controlled inverter and 8 contact pins ( el001 ? - WHITE ) - 38 EUR (Leaniz)
    *1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For Vectra A - 7Krpm, 20-220kmh, 60l (VECTRAAP - Blue/white) - 95 EUR (eduskap)
    *1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For Astra F GSi16V - 8Krpm, 240kmh, 50l (ASTRAFP - > Blue/white) - 95 EUR (astur_gato)
    *1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For CalibraTURBO - 8Krpm, 20-280kmh, 60L - 110ºC (CALIBRAP - > Blue/white) 95€ (vectra2)
    *1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For VDO´s (VDOOPCP) - > Blue/white - 31,5€ (vectra2)
    *1 Set of 'special' dials with EL-Foils cutted and a chip controlled inverter. For Astra F GSi16v - 110 EUR (cicli)
    Estamos todos no?
