Resultados 1 al 10 de 193
Tema: [PEDIDO CONJUNTO] Esferas de Plasma
    Predeterminado Re: [PEDIDO CONJUNTO] Esferas de Plasma
    a ver, el numero de cuenta para el ingreso os lo daré por privado, ok?
    vamos a hacer un repaso: (los que tienen el subrayado sobre el nombre, es que están confirmados
    CICLI> -1 Set of "special" dials (I will send you a pic of the design of the dials. Are similar to the factory dials) with EL-Foils cutted and a chip controlled inverter. For Astra F GSi16v - 110 EUR
    K_V6> -1 Set of cutted EL-Foils with chip controlled inverter and wires for Vectra A ( EL1000 ? - WHITE ) - 48 EUR
    YO> -1 Set of cutted EL-Foils with chip controlled inverter and wires for Astra F ( EL1000 ? - WHITE ) - 48 EUR
    Bufarron> -1 Set of EL-Foils for DIY with chip controlled inverter and 8 contact pins ( el001 ? - WHITE ) - 38 EUR
    Eduskap> -1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For Vectra A - 7Krpm, 220kmh, 60l (VECTRAAP - Blue/white) - 95 EUR
    B.A.D> -1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For Vectra A - ¿?rpm,¿?Kmh, ¿?L (VECTRAAP - ¿?) - 95EUR
    Bixo> -1 Set of Dials, EL-Foils cutted, wires and chip controlled > inverter. For Astra F GSi16V - 8Krpm, 240kmh, 50l (ASTRAFP - Blue/white) - 95 EUR
    Astur_gato> -1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For Astra F GSi16V - 8Krpm, 240kmh, 50l (ASTRAFP - > Blue/white) - 95 EUR
    Vectra2> -1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For CalibraTURBO- Falta especificar el modelo concreto (hay dos) uno con los numeros en horizontal y otro con los numeros sobre el arco de la esfera. Tambien falta decir, la capacidad de L de gasolina y el maximo que marca el reloj de temperatura del motor, 100 o 110 ¿?¿? 95€
    Vectra2> -1 Set of Dials, EL-Foils cutted, wires and chip controlled inverter. For VDO´s (VDOOPCP) - > Blue/white
    07 Jan, 05
    Vectra 2000
    Leaniz16v> -1 Set of cutted EL-Foils with chip controlled inverter and wires for Vectra A ( EL1000 ? - WHITE ) - 48 EUR
    Gracias Billy!!!!
    P.D. Tu dirás el número de cuenta y cuándo ingresar!
    C20XE pawaaaaaaaaaaaa
    06 Jun, 06
    kadett gsi
    Cita Iniciado por Leaniz16V Ver mensaje
    Gracias Billy!!!!
    confirmado
    gracias chicos...
    Astur_gato, los precios que me ha dado de las esferas son las estandar, que son sin logo...
    06 Nov, 07
    Astra gsi16v
    ok gracias , todo perfect
    From Asturias con amor.
    Astra gsi 2.0 16v del 93
    Mensajes Privados mandados
    Recibido el pago de:
    Cicli
    Bufarron
    Leaniz
    faltan:
    Eduskap
    Astur_gato
    Vectra2
