Body
- Two door coupe or convertible (Volante) body style with 2+2 seating
- Extruded aluminium bonded body structure
- Aluminium and composite body panels
- Extruded aluminium door side impact protection beams
- High Intensity Discharge (HID) projector lamps (dipped beam)
- Halogen projector headlamps (main beam) with power wash
- LED rear lamps
Engine
- All alloy, quad overhead camshaft, 48-valve, 5935cc V12
- Compression ratio 10.3:1
- Visteon engine management controlling fuel injection, ignition, diagnostics and misfire detection system.
- Stainless steel by-pass valve exhaust system
- Maximum power 335 kW (450 bhp) at 6000 rpm
- Maximum torque 570 Nm (420 lb ft) at 5000 rpm
- Acceleration 0-60 mph in 4.9 seconds
- Maximum speed 186 mph (300 km/h)
Transmission
- Rear mid-mounted 'Touchtronic 2' six-speed gearbox with electronic shift-by-wire control system
- Rear mid-mounted six-speed manual gearbox
- Limited slip differential
- Final drive ratio 3.54:1 (manual) / 3.154:1 (Touchtronic 2)
Steering
- Rack and pinion, servotronic speed-sensitive power-assisted, 3.0 turns lock to lock.
Column tilt and reach adjustment
Suspension
- Front: Independent double aluminium wishbones incorporating anti-dive geometry, coil over aluminium monotube dampers and anti-roll bar
- Rear: Independent double aluminium wishbones incorporating longitudinal control arms, coil over aluminium monotube dampers and anti-roll bar.
Brakes
- Radial-mounted four-piston monobloc calipers, Anti Lock Braking System (ABS), Electronic Brakeforce Distribution (EBD), Emergency Brake Assist (EBA), Dynamic Stability Control (DSC) and Traction Control
- Front: Ventilated and grooved steel discs 355 mm diameter
- Rear: Ventilated and grooved steel discs 330 mm diameter
Wheels & Tyres
- Lightweight aluminium 19" alloy wheels - 10 spoke design
- Front: 8.5J x 19
- Rear: 9.5J x 19
Tyres
- Front: 235/40 ZR19
- Rear: 275/35 ZR19
Interior
- Full grain leather interior
- Walnut facia trim
- Driver and front passenger dual-stage air-bags
- Front occupant side air-bags
- Automatically deployed roll-over bars (Volante)
- Memory seats and exterior mirrors (3 positions)
- Ten-way electrically adjusted seats (including height, tilt and lumbar adjustment)
- Heated front seats
- Heated rear screen
- Automatic temperature control
- Organic electroluminescent (OEL) displays
- Trip computer
- Cruise control
- Powerfold exterior mirrors
- Reversing sensors
- Tyre pressure monitoring *1
- Alarm and immobiliser
- Remote-control central door locking and boot release
- Aston Martin Umbrella and holder
- Battery disconnect switch
- Battery conditioner
- Linn 128 W audio system with radio and six CD autochanger
Dimensions
- Length: 4710 mm
- Width: 1875 mm
- Height: 1270 mm
- Kerb weight: 1760 kg (manual) 1800 kg (automatic)
- Fuel tank capacity: 80 litres
- Wheelbase: 2745 mm
- Boot capacity: 186 litres
- C02 Emissions: 421 g/km (manual) / 394 g/km (touchtronic)
Optional Equipment
- Sports Pack
- Bright finish grille
- Front parking sensors
- Mahogany, Bamboo or Piano black facia trim
- Matching wood door trim
- Personalised sill plaques
- Auto dimming interior rear view mirror
- Auto dimming interior rear view mirror with garage door opener*1
- Heated front screen
- Alarm upgrade (volumetric & tilt sensors)
- Tracking device*1/2
- Integrated GSM telephone
- Alternative brake caliper finish (black, red, silver)
- Sports Pack (Coupe)
- 19’’ alloy wheels – 15 spoke
- First aid kit
- Smokers’ pack
- Linn 260W audio system with Limbik 5.1. Linn 950W audio system with Dolby Pro Logic II.
*1 Not available in all markets
*2 Complies with UK Thatcham Category 5 requirements. Excludes subscription. Standard in the UK.
