Resultados 1 al 10 de 75
Tema: mas esferas
    04 Dec, 03
    Vectra Irmscher
    Predeterminado Re: mas esferas
    Me podría interesar
    Un tipo 2
    Apuntame Billy
    Vectra A 3000 V6 24V F28
    apuntado usted ha quedado
    Le he enviado otro correo con las preguntas estupidas que damos por supuesto, para que nos las confirme y asi no haya ninguna sorpresa:
    Hi Seba!!!
    The order will be probably more than 10 units, when I know exactly the
    number of units, I tell you the final number of the units, for you can make a budget, and say me the
    total price of the order (shipment costs included) before we confirm the
    order, ok?
    Well, We have some questions that you could answer it before of nothing:
    - They intensity of brightness can be regulated with the original
    potenciometer or they have fixed intensity?
    - The dials work correctly with the inverter or they need something more?
    - Do you include a fitting instructions?
    - The discount, is for any 10 units (vectra, astra, calibra,
    kadett,...normal, V6, turbos...) or must be 10 from the same kind???
    picture attached)???? If you see it, the interval scale from 0 to 60 KMH
    is different of the scale 60-260 (more small than the first range)
    - The dials could be specified? for example, can I order a "sample 2"
    with a white illumination and a turbo scale (0-280KMH) ???
    voy a poner en el primer mensaje del post la lista de apuntados, para que esté mas visible, ok?
