Resultados 1 al 10 de 14
Tema: Doble luz de freno
    Predeterminado Doble luz de freno
    Brico sacado de una web "compañera" africana (si, es la ola africana, jaja)
    http://www.opelownersclub.co.za
    copy/paste.
    Some Opel Mk.3 Kadett owners might have once or more replaced a rear cluster bulb, some might have noticed that there is actually 5 bulbs, 4 of which are usually used. There is however a way to use this extra bulb to aid in making your car much more visible when braking. This is an DIY guide how to do just that.
    Firstly remove the bracket from the rear light cluster and disconnect the wiring plug. This is what you will see (this is the right hand side one).
    As can be seen the lower left bulb is the currently unused one. The connection that needs to be made to share a circuit with the existing brake light is shown also.
    To ensure the connection does not get loose (due to the weird surface on the metal connections, you might need to scrape or roughen the soldering spots with some sanding paper or a sharp object. Use a small piece of wire, and carefully solder the two sections as displayed as not to cause shorts or blown bulbs and fuses.
    This is what you will end up with if you do everything correctly. Much more visible to people tailgating you
    Thanks to 200Darter on the Opel Owners Club Forum for this little gem
    Esta bien y parece facil, pero por esta regla de 3, que pasaría si encendieras la luz del antiniebla? se encendería tambien la del freno? Bueno, ahi queda...
    1.6 16V sport Irmscher
    Predeterminado Re: Doble luz de freno
    jejeje, claro como en África supongo que no sabrán lo que es la niebla, pues quizás no lleven ni luz de niebla de serie.
    Lo mejor es la tercera luz de freno, que parece una chorrada pero hace que te vean bien y de librarse de que más de uno te coma el culo.
    gracias por el brico Emilio
    Jorge
    ______________
    Vehículos;
    14 Jun, 05
    Astra Gsi
    ke wapo el kadett XD
    10 Aug, 03
    Portugalete (EH)
    Con esas luces de freno el coche parece un "desdentado"..... .
    19 Nov, 05
    Jaen
    Pos klaro, al dar las antinieblas se encienderá la del freno; la solución ta en poner un diodo en evs dun kable. Saludos
    15 Jun, 04
    Astra GSI 16v
    La cosa en si no esta mal, pero ademas del problema que dice Benji, date una vuelta por este pais con las luces asi y luego me cuentas que tal lo has pasado xD
    Proximamente... OVERFIBER
    04 Mar, 06
    jode, que esta mal tener las luces asi? yo las tengo asi en los lexus osea no esta soldado el cable ese, tengo empalmado el cable por dentro y lo de la antiniebla tengo una bombilla de doble contacto y listo
    Y eso de que en África no hay niebla.....
    ¿donde rodaron Gorilas en la Niebla? jajaja.
    04 Apr, 06
    Astra GSI EDITION
    Mmmmmmmmmmm vaya kadett mas moderno no? Edicion limitada!!!!! xdddddd
    Marcos
    15 Jun, 04
    Astra GSI 16v
    Mad, ojito que asi no pasas la itv... si pisas el freno, se tienen que encender SOLO la luz de freno, jeje
  1. Sin freno de mano, ayuda urgente!
    Por sapito_txikia en el foro Dinámica
    Respuestas: 11
    Último mensaje: 17-12-05, 00:29
  2. Problema de los freno arreglado
    Por opelGSI en el foro Dinámica
    Respuestas: 7
    Último mensaje: 01-12-05, 21:25
  3. luz de freno, se me a kedado pillada
    Por Qmack1.6S en el foro Mecánica
    Respuestas: 7
    Último mensaje: 17-11-04, 22:25
  4. Bomba de freno Manta
    Por Daviz en el foro Dinámica
    Respuestas: 7
    Último mensaje: 25-02-04, 21:40
  5. Luces de freno
    Por MARS en el foro Electricidad
    Respuestas: 3
    Último mensaje: 16-11-03, 13:45
