Resultados 1 al 5 de 5
Tema: Error Nº 24 en c16nz
    06 Oct, 03
    Predeterminado Error Nº 24 en c16nz
    Os queria comentar un error que sale de vez en cuando en el kadett cabrio de mi madre. Se trata del error 24, lleva una centralita Multec y por lo que he buscado se trata de "Error en impulsor de frecuencia recorrido"
    ¿Alguien sabe de qué se trata?
    Gracias
    ¡Hay tantas cosas en la vida más importantes que el dinero! ¡Pero cuestan tanto!
    Y tú, ¿Tienes máquina?
    rubio.cazorla@gmail.com
    05 May, 04
    Kadett E GSI
    sacado de topbuzz:
    GM-Multec ECU Fault Codes
    This fault code chart shows the GM-Multec fault codes for the following systems:- SPi, MPi, CFi, M and S.
    GM-Multec Code Chart: To the top
    Code: Item:
    Fault:
    12 Initiation of diagnosis. n/a
    13 Oxygen sensor No change in voltage/open circuit.
    14 Coolant Temperature Sensor (CTS) Low voltage
    15 Coolant Temperature Sensor (CTS) High voltage
    16 Knock signal circuit n/a
    18 Knock control processor n/a
    19 Crank Angle Sensor (CAS) Incorrect RPM signal
    21 Throttle Potentiometer Sensor (TPS) High voltage
    22 Throttle Potentiometer Sensor (TPS) Low voltage
    24 Vehicle Speed Sensor (VSS) No speed signal or low voltage
    25 Injector valve Low voltage
    28 Fuel pump relay contacts Contact problem
    29 Fuel pump relay Low voltage
    32 Fuel pump relay High voltage
    33 Manifold Absolute Pressure (MAP) sensor High voltage
    34 Manifold Absolute Pressure (MAP) sensor Low voltage
    35 Idle stepper motor Poor or no idle speed control
    41 Amplifier control signal, cylinders 2 and 3 (Direct Ignition System (DIS)) High voltage
    42 Amplifier control signal, cylinders 1 and 4 (Direct Ignition System (DIS)) High voltage
    43 Primary ignition (distributor systems) High voltage
    44 Oxygen sensor Air/Fuel mixture too lean (weak)
    45 Oxygen sensor Air/Fuel mixture too rich
    46 Amplifier (Direct Ignition System (DIS)) control signal (A+B) High voltage
    47 Linear exhaust gas re-circulation (EGR) position n/a
    49 Battery supply to Engine Control Unit (ECU) High voltage (greater than 17 volts)
    51 Engine Control Unit (ECU) Defective ECU (disconnect and reconnect (ECU), then recheck for fault codes). Memory failure
    52 Secondary air pump relay Low voltage
    53 Secondary air pump relay High voltage
    54 Idle Carbon Monoxide (CO) potentiometer n/a
    55 Engine Control Unit (ECU) fault Renew Engine Control Unit (ECU)
    56 Air control soleniod Low voltage
    57 Air control soleniod High voltage
    61 Fuel tank vent valve (FTVV) Low voltage
    62 Fuel tank vent valve (FTVV) High voltage
    63 Amplifier control signal, cylinders 2 and 3 (Direct Ignition System (DIS)) Low voltage
    64 Amplifier control signal, cylinders 1 and 4 (Direct Ignition System (DIS)) Low voltage
    65 Primary ignition (distributor systems) Low voltage
    66 Throttle position sensor (TPS) Hose broken
    67 Air Flow Sensor (AFS), hot wire meter (air mass meter) Signal is outside normal operation parameters (out of range)
    68 Air Flow Sensor (AFS), hot wire meter (air mass meter) Faulty air mass meter signal, incorrect frequency
    69 Air Temperature Sensor (ATS) (MPi only) Low voltage
    71 Air Temperature Sensor (ATS) (MPi only) High voltage
    72 Amplifier (Direct Ignition System (DIS)) control signal (A+B) Lead interruption, open circuit
    75 Torque control (Automatic Transmission (AT) only) Low voltage
    76 Torque control (Automatic Transmission (AT) only) Continuous
    81 Injector valve High voltage
    83 Immobiliser No or wrong code
    84 Immobiliser No signal
    85 Immobiliser Wrong signal
    87 Air conditioning cut-off relay Low voltage
    88 Air conditioning cut-off relay High voltage
    92 Camshaft sensor Faulty hall effect sensor or circuit
    93 Quad drive module (in ECU) n/a
    va a ser del sensor de velocidad.
    :wink:
    Indice de mecanica
    06 Oct, 03
    Lo que no entiendo es a que se refiere, ¿al transductor que entra en la caja de cambios?
    Juraria que no lleva, que simplemente lleva sisga hasta el velocimetro, de todos modos lo mirare...
    gracias
    1.6 16V sport Irmscher
    Hola Álvaro
    A mi me dió ese fallo cuando se me partió el cable del velocímetro
    revisa el cable
    Jorge
    ______________
    Vehículos;
    24 Aug, 05
    Astra GSI 16V
    Predeterminado Re: Error Nº 24 en c16nz
    Joder loq ace mirar jejeje mira lo q e encontrado aora tengo yo este fallo en mi astrita puedes decir como lo solucionastes???
    Gracias de antemano
    Un sueño hecho realidad...
  1. Sistema de diagnóstico para C16NZ
    Por UZIELGAL en el foro Electricidad
    Respuestas: 0
    Último mensaje: 25-07-05, 19:06
