Resultados 1 al 10 de 13
Tema: Los verdaderos OPC :) (post fotografico pesado)
    05 May, 04
    Kadett E GSI
    Predeterminado Los verdaderos OPC :) (post fotografico pesado)
    DTM:
    http://www.opel-performance.com/imag...eug_001_03.jpg
    Vehicle: Opel Vectra GTS V8
    Engine
    Type: V8-engine, longitudinal at front, cylinder bank angle 90°, cylinder interval 102 mm, four chain-operated overhead camshafts, four valves per cylinder, two air-intake restrictors with a diameter of 28 mm each
    Displacement: 3998 cc
    Bore: 93.0 mm
    Stroke: 73.0 mm
    Compression: 13.0:1
    Output: approx. 348 kW/475 hp at 6,800 rpm
    Max. torque: approx. 510 Nm at 5,500 rpm
    Engine management: Bosch MS 2.9.2
    Emission control: three-way catalytic converter
    Lubrication: dry-sump
    Transmission: longitudinal transaxle competition gearbox (DTM control part, manufacturer: X-trac) with six spur gears, non-synchronised, sequential gearshift, fixed gear ratios, variable total ratio; carbon fibre clutch, mechanical self-locking differential; rear wheel drive
    Body: tubular frame with integrated CFK driver’s safety cell, integrated safety concept with crash boxes at front and rear as well as lateral crash structure, double-layer aerofoil with DTM control profile
    Fuel tank: 70 l
    Length: 4,883 mm
    Width: 1,850 mm
    Height: 1,250 mm
    Wheelbase: 2,800 mm
    Track: 1,600 mm front, 1,550 mm rear
    Suspension: double wishbones front and rear, central wheel mounts, adjustable anti roll-bars front and rear, shock absorbers compression and rebound adjustable, power steering
    Wheels: front 10x18 inch, rear 11x18 inch
    Wheels: front 265/660 R18, rear 280/660 R18 (DTM control tyres, manufacturer: Dunlop)
    Tyres: front self-ventilated carbon discs (diameter 380 mm),
    rear self-ventilated carbon discs (diameter 340 mm), aluminium brake callipers with six pistons front and four pistons rear (DTM control parts, manufacturer: AP)
    Weight: 1,080 kg, driver included
    Hockenheim:
    EuroSpeedway
    Yo kiero un patrocinador asi!!!!!!!
    Spa-Francorchamps
    Bruenn
    Indice de mecanica
    05 May, 04
    Kadett E GSI
    GM Sport
    Le Mans:
    BTCC
    WTCC:
    Indice de mecanica
    05 Aug, 03
    S3
    El que está patrocinado por PB me encanta XDDDD
    Ya iba bien encaminado cuando el verano pasado enganché la pegatina de PB en mi capó!
    6º ANIVERSARIO
    ZARAGOZA
    05 May, 04
    Kadett E GSI
    No se porke me esperaba una respuesta asi tuya, xDDDD
    Indice de mecanica
    05 Aug, 03
    S3
    ¿Por qué lo dices?
    :XD:
    6º ANIVERSARIO
    ZARAGOZA
    06 Sep, 03
    Vectra B
    Los Chevrolets esos que salen no son lo que en Europa vulgarmente llamamos "Astra G"?
    Esque tienen muchisimo parecido.
    Club Vectra B
    Vectra B 1.6i 16V X16XEL (¿105 cv?)
    10 Aug, 03
    Portugalete (EH)
    Los pilotos traseros de ese Chevrolet no son los mismos que los de un Rover 45?
    05 May, 04
    Kadett E GSI
    ES lo que vende chevrolette de ese lado del charco,Chevrolette es el peso pesado de GM, en todos los grupos hay intercambio de chasis entre marcas, y chevrolette no iba a ser una excepcion, almenos tiene toa la pinta.
    El modelo esn cuastion es el chevrolette Nubira, o lacetti (dependiendo del mercado).
    Los datos del WTCC:
    http://www.eldiferencial.com.mx/content/view/188/28/
    Dimensiones
    Batalla
    2,600 mm
    Longitud
    4,500 mm
    Anchura
    Según normas FIA
    Altura
    1,360 mm
    Anchura de eje del.
    1,560 mm
    Anchura de eje tras.
    1,560 mm
    Peso
    1,140 kg
    Capacidad tanque
    70 litros
    Chasis/Suspensiones/Neumáticos/Ruedas
    Estructura
    Monocasco en acero con célula de seguridad reforzada
    Carrocería
    En acero, carbono y kevlar con kit aerodinámico motorsport, según normas FIA
    Suspensiones delanteras
    McPherson
    Suspensiones traseras
    De barras dobles
    Ruedas y Neumáticos
    Rines de competición en aluminio, 9" x 17"
    Neumáticos de competición Michelin
    Frenos delanteros
    Calipers de 4 pistones en aluminio, discos ventilados en acero 295 x 32, refrigeración por aire
    Frenos traseros
    Calipers de 2 pistones, discos en acero, 290 x 9.7
    Motor
    Tipo
    4 cilindros, 2 litros
    Cilindrada
    1,998 cc
    Sistema de alimentación
    Inyección individual, acelerador de 64 mm
    Válvulas
    16 válvulas, mandadas por empujadores, diámetro válvula de admisión: 34 mm, válvula de escape: 28 mm, muelle de espiral
    Compresión
    11:1
    Potencia
    270 HP a 8,400 rpm
    Par
    197 ft/lbs a 5,800 rpm
    Velocidad máxima (estimada)
    158 mph (254 km/h)
    Transmisión
    Tipo
    Caja secuencial de 6 velocidades
    Mando mecánico
    Y pa aprovechar el filon han sacado el WTCC R+ de calle , con 100 cvs menos (172)
    http://www.autoglobal.com/noticias/5500/5602.html
    Indice de mecanica
    03 Aug, 03
    Vectra 2000 16v
    Acojonante.
    Menuda currada Albert, gracias macho.
    Cuando esté rodado el post lo muevo a DESTACADOS.
    Digno de hacerlo en PDF.
    Gracias de verdad...he disfrutado con cada una de las fotos que has puesto.
    Alex.
    05 May, 04
    Kadett E GSI
    No podia dar con un filon asi y no compartirlo
    La vedad es ke lo he pasado fatal en esa pagina , he descubierto lo mala ke es la envidia :lol: :lol:
    Indice de mecanica
  1. Respuestas: 11
    Último mensaje: 22-03-05, 15:04
  2. Kadett Fenix!-Finde de reparaciones (Post pesado)
    Por MARTYN en el foro Mecánica
    Respuestas: 3
    Último mensaje: 01-06-04, 13:27
